No need to use a bigger bolt after I drill out the broken bolt ?Remove the remaining amount of the existing bolt; chase the existing threads w/a tap if they need it, & use another correct/new bolt.
He’s saying if you can get the bolt out with an extractor you’ll need to chase the threads with the same size tap for any threads you may have damaged.No need to use a bigger bolt after I drill out the broken bolt ?
No need for a bigger bolt or helicoil ?
Just drill out, tap, and install the same size bolt ?
No he's saying drill out and destroy/eat away the broken bolt, tap/rethread, install the same size bolt... it's damaged past the point of extraction... Which is why he's suggesting destroying/eat away the broken bolt with a drill...He’s saying if you can get the bolt out with an extractor you’ll need to chase the threads with the same size tap for any threads you may have damaged.
Understood...If you can try and clean up the RTV around the opening of the hole. Then clean it with brake clean or carb cleaner and get a few good photos to share of the broken bolt. I think this will aid us in providing you the best guidance.
Gotcha, and understood.Incorrect. I'm saying what bruisedbanana79 said.
If you think you can drill out that bolt to be able to put a bigger bolt in..... Then that means you think you can drill out what's in there. Regardless of size, you're still drilling to remove material.
if you don't use the correct methods to remove the bolt, you will not have a hole suitable for a larger bolt.
If you can drill it out en-masse for a larger bolt, you should be able to drill out the current bolt. It takes the same effort & finesse either option.
I wouldnt go for a fractional size larger. If the hole is shot I would go up the next larger size in metric. This way it might not be a huge size difference. Just a thought.Incorrect. I'm saying what bruisedbanana79 said.
