Just tried it. It gave my car power cuz the lights turned on. Wouldn't crank tho. Looks like I'm just going to have to wait for my batteryFor most cables it needs a bat
Ok, I'll see if I can do that. Do you need a special tool to check for spark?did you check to see if you are getting spark?...if you are try retarding the timing a bit. Your filter has gas it so the carb should be getting some.
No, pull a plug wire off and hold it close to the plug...when you crank you will see an arc of electricity trying to close the circuit. If you see the arc, you are getting spark.Ok, I'll see if I can do that. Do you need a special tool to check for spark?
Btw, changed that vacuum line haha
Edit...or pull a wire off the cap and check for an arc there if its easier...don't wanna burn your hand on a manifold or header. Definitely hold the wire and not the plug boot....30K+ volts sting pretty good, take it from experience lol!
Welllll Steve, one of those blips in concentration years back....gotta nice little jolt !! Woke me the hell up that's for sure lol!now why did you have to warn him.....
