Tips for changing intake manifold
LukeZ
Thread starter
Apr 24, 2015
537
Delaware
SHE STARTS!!!
But she runs a little rough. I turned the distributor a little counterclockwise and it fired up. Question. Can I adjust the distributor while the car is running? Or do I have to shut it off every time I want to turn it?
It also shot a sh*t load of black stuff out of my exhaust pipe. I think that was just all the mess that got in the heads while I was working
  • Winner
NickC
38
8
SHE STARTS!!!
If it's running and needs little tweaking I'll leave it running I find it best to let the motor warm up
Opie Knievel
Rum Fueled Midnight Mechanic and Moderator
Moderator
Sep 6, 2010
1,510
Brodhead, Kentucky
SHE STARTS!!!
Yes you can turn the distributor while the car is running.
Letting it warm up will make it easier to tune.
pontiacgp
blank
Mar 31, 2006
29,276
Kitchener, Ontario
the black stuff is just the excess fuel burning off and use a timing gun to set your timing, with the vacuum advance plugged. Turning it counterclockwise advances the timing
Reactions: 4 users
axisg
2,681
YYZ
Yippee ! Always good when the patient wakes up after anesthesia !
LukeZ
Thread starter
Apr 24, 2015
537
Delaware
So my dumb *ss forgot to put some sort of stoper in my new intake. It has a hole right where the coolant runs through that I didn't even notice. Made a little mess of antifreeze but that's how you learn I guess. Need to go to the hardware store and but a threaded plug.
Another question. Anyone know what this does? Runs from the passenger valve cover to my air cleaner, and there's a little foam filter on the other side of that white plastic nozzle coming out of the air cleaner.
Yet another problem that arises because of the increased height haha. Do I absolutely need this? And no, I can't just pull it out and bend it. She's in there, and it's attached to something. On the other side of the valve cover there's is a metal flap that I assume let's oil into the air cleaner? Not sure.
If I don't need it, I'll just stop up the holes on both ends for now. If I do need it, I guess I can try to fab something up.
pontiacgp
blank
Mar 31, 2006
29,276
Kitchener, Ontario
you can get a fitting to go into the valve cover grommet and use a hose to attach the two fittings to each other.
LukeZ
Thread starter
Apr 24, 2015
537
Delaware
Good idea. I just don't want to tear anything up by ripping that thing out. I'll give it a shot though
  • Friendly
