? To QP Ford 9 owners
melloelky
4,164
9,571
mass
My ford went,everything goes on te axle.The seal goes on the axle,press the bearing on,press the steel ring on.
1,167
2,638
West Virginia
The steel ring is a secondary bearing retainer
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,828
They sent me the wrong seals for my billet F body ends when i got my axle. i tried to use the seals inside the axle and it was a no go. Ill see if i have pics tonight. If not ill be home tomorrow and post pics from my ford 9 service book.
Doug Chahoy
2,565
2,663
My seals seem to be ok, they slide in about half way. I just have to find a socket big enough to knock it all the way in. How did you press the bearing and retainer ring on?
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,828
I didnt need a retainer because I had sealed big bearings. If I recall correctly. I'll get you a pic when I get home.
20,391
did you put an inner seal in before you installed the 3rd member? Without the inner seal they'll be a good chance of an axle leak.
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,828
I had this style. Big bearing sealed bearings. No internal seal.
