Trans cooler lines leak at radiator
200kss
20
Missouri
I've installed 2 new radiators in 2 different cars. 1 a higher end aftermarket aluminum radiator and the other a standard plastic/aluminum replacement. Neither of them will seal at the upper transmission cooler line port. Adding Teflon tape to the threads slow the leak down to just a trickle
-83MONTESS-
4,570
967
Bellevue, Ohio
Are you using the right fitting? Is it a pipe thread or straight thread?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
if two rads leak and teflon tape only slows it down I would be looking at the flare on the pipe, you'll probably have to cut it off and flare it again. The tube nut is probably ok to use it again
565bbchevy
9,614
12,683
Michigan
What are your trans lines made of?
200kss
20
Missouri
These are original lines, that did not leak with the previous radiators. Hard to believe both new radiators have issues but I have verified the lines are not cracked nor cross threaded.
565bbchevy
9,614
12,683
Michigan
2 radiators with the same issue make the lines most likely the culprit, You can replace the lines with Cunifer tubing and they will seal better.
