yes i put them in becus the car was not siting right and the guy befor me put shorter springs in.. i had to take the new ones out to install the new rubber bushings... the spring is set in the lower and upper pocket right..
its possible that the upper arm is bent slightly and binding when you tighten it. If the bushings were installed properly, that would be the only possible answer, based on your description of the problem. can you take a pic of the upper A arm from inside the engine bay?chevyfan16 said:I havent had a chance to take pictures of the rear. I am in the middle of installing a 700r4. I still dont understand how it would sit level when I loosen up the upper bushings, but when I tighten them and bounce it, its uneven again!
