Phoenyx said:Did a few things today:
Put the new water pump back on:
Put a double spring on the throttle:
I think I'm going to change where it mounts to. But at least it's on there for now
Mounted the transmission cooler. Not plumbed in yet:
I had to remove the a/c condenser to mount the cooler. And since that jackass mechanic decided to remove most of my a/c, I didn't need it anyway. But I had some trouble removing the fan shroud. 2 of the bolts wouldn't come out (clips are broken I think). So I had to do a bit of breaking.
2nd bolt from the left was tight down, so I had to break it around the bolt.
Far bolt to the right was fairly loose, but couldn't be backed out any more. It was already cracked, so I just enlarged the crack so I could slide it off.
Normally I wouldn't have done this. But the shroud was already damaged from a plastic flex fan blowing apart a few years ago.
Put in some new headlights. Sylvania's best bulbs.
And when I took the grill out, one screw just kinda fell out. and there was another just laying on the bumper (I'm lucky I didn't lose it lol). I'm missing 2 of these clips:
Anyone know if these are still available?
Tomorrow I hope to plumb the cooler in, and put everything back together under the hood.
Bonnewagon said:I used it to pick up the Grandson at school today. I wanted the AC on and it was weak, so it's back to the sniffer again. I think my schreader valves are leaking.
1984 Cutlass said:Took the Cutlass to the transmission shop to fix the leak, which turned out to be many lol. I have had a few people look at the trans with no luck of tracking down the exact problem. Sometime you have to bite the bullet and go to the pros who know their stuff... Luckily I brought it there because they found my actuator lever for the kick down cable was broken off. I have wondered why my car shifted so weird, thought the cable wasn't adjusted properly. I have not hit fourth gear in this car since I have owned it,just wastes gas and doesn't kick down. Now the car is fast! About freakin' time! No more huge trans period stains lol🙂
