L.A.X-RATED said:
removed the front clip,and got rid of all the clutter(ac/heater :puke: ) on my sons 79 "potty training day" mc(awaiting a por-15 bath,weld-in ac/heat delete panel/shaved firewall,and big brake upgrade :wink: ).also bolted in/fit some 03 mc black leather guts,as well as drilled my RUST FREE trans tunnel for my floor shifter and 03 mc center console(just the top plate,i have to shave down the console body as i want a low mount fit),and fit/welded up some 87 sport mirrors 8)
u should post them seat,an what u did to make them fit on the "What seats have been used in G Body's?" thread,
here' the link
viewtopic.php?f=16&t=42839
87luxsprt said:
Can u show how ur mounting those front seats. I have a pair of those with the original brackets. But wondering how hard it would be to put on my project 87 MC. Thanks
simple,turn them over and measure 14" from center to center on the underside of the newer mc seats(or 1/4 inch in from the outer edge)mark and drill new holes.check fitment of gbody tracks,you will use existing bolts,spacer.you will only need to get 12 washers to use,3 underneath each factory washer/spacer,and one under the bottom of the track where it bolts to the bottom of the mc seat.track,bolt,spacer,3 washers,track,washer,bolt to seat :wink: did i see you at the pomona swap meet? i could have sworn i seen that lux in your avatar,but it had irocs,and a female was driving?
here' the link
the homie/member josh "lowproelco" has already documented the install with video and all :wink: iirc,the thread is entittled"02 mc seats in my gbody" its on this forum as well as gbody central.
I was out there the last few nights in the shop, cutting and welding the parts for my rotisserie. 😀
Pour gas down it's throat so it would start easier,didn't know if the battery still had a charge,fired right up though,Pulled it out of the garage,an snapped a few pics of the dusty engine compartment
NO GARAGE, SO I USE THE SIDE OF THE ROAD... pulled the motor out of my monte, and dropped a new one in (almost)... got dark out and couldnt see to line the motor up to the transmission...
MID WORK PICTURE
Went out for my first drive in my Malibu since last September. Ran good. Got to finish putting it back together
I know about curbside engine swaps. With shade for the critics.
