drove it to work today. With the colder weather I started messing with the choke. If I set the spring tight enough to almost close at cold then it doesn't want to kick off the high idle cam when warm ! If I set it just a couple degrees back then the choke flap stays open and it wont idle cold.
It did this last year as well so I changed the choke spring, now seems I am having the same issues. :/
do you have 12 volts on the wire to the choke? If you still have the pressure switch near the distributor if that is detective it will not transfer the power to the wire going to the choke
yes, I was getting fluctuating readings from the choke wire last year so I jumped off a switched 12v+ power lead instead.
I replaced my summer 160* thermostat with a winter 195*. It made the motor overheat. I tried a second, same thing. Then I tried a third, same thing. I had tested all three in a pot of water on the stove with a candy thermometer and they passed. But when in the car they ran way too hot. In desperation I used a 180* left over from another car. It worked great, right on the money. Motor runs better and I still have good heat inside. I don't know what the deal is with these thermostats but I'm getting pretty tired of them failing so often.
Trying to trade my regal for a mildly rusty 1969 charger the guy wants 3500 for. Probably not gonna happen, but I can dream.
Reactions: Opie Knievel
Brought home a replacement for my 301, a 1967 400!
During disassembly, found these little guys in the lifter valley and oil pan. Broken push rods. 😕
At least you were gonna change the cam anyway, lol. Ive bent a couple in my time, but my lord I've never seen any in a non top fuel motor that were straight up broken.
Not only broken, they had been replaced with new pushrods and the broken pieces remained inside the engine!
:O
