Eeek yeah that needs a tweaking!Transmission is bolted to crossmember, but I need to straighten the motor out. It's definitely not square and its pissing me off.
Here is mine from a couple days ago for reference...
Man I can’t wait to see you get this done!Put it back on the ground so I can do stuff in the engine bay and trunk easier. Also took some shameless engine pics, and checked out ground clearance with the deep trans pan.
Gonna try to burn some midnight oil when the kids crash. View attachment 113821 View attachment 113822
Yep. Here is a link to my build thread...Man I can’t wait to see you get this done!
Have you posted pics of the whole car? I’ve only see pics of the bay. Lol
Looks we're both tackling fuel pump conundrums Steve. I removed the A1000 earlier, changed the 10 micron post filter, and now I'm at a standstill. I have the pre filter hooked to the pump. But I need a different adapter to go from the pump to post filter...I started putting the fuel line together. I am using Russell tube sleeves and adapter nut to use the 3/8 aluminum tubing with an fittings. The angle on the sleeves for the single flare is 37 degrees but the common flare kit is a 45 degree. the 37 degree flare is expensive but the 45 degree will work so it makes it cheaper than using the Russell crimp design adapter...the other advantage is you can cut the flare off and reuse the tube sleeve unlike with the crimp you can only use it once.
