I think it was a module that plugged into the diaphragm.What was the brain for it on a carb'd car?
Early cars had a transducer (I think that is the right term) that the speedometer cable ran to from the transmission. It was mounted up on the driver's side inner fender. A shorter speedometer cable ran from it to the gauge. The transducer, the vacuum actuator and the switch on the column was all there was to it other than the brake light switch (unless if I'm missing something).What was the brain for it on a carb'd car?
Let me know what other angles you want and I'll snap you any photos you need Nick.Cauterize, that picture you posted of your motor shows a situation that is about as classically stock as the top of an intake can get! GREAT Reference picture for someone looking to identify all the various hoses and wires. Even shows the cruise control body.
Nice and crisp shot; I do plan on adding a copy of it to my reference pages. Any more along the same line to share?? Huh? Huh?? Huh???
Later cars didn't use the transducer. Instead, they had an optical sensor on the back of the speedometer that provided the speed reference. They also have a little module that mounts to a bracket above the throttle pedal.
This is all from memory so guys, please correct me if I'm wrong.
you are correct on the early cars. I sold a system off the flooded elkie I bought last year, needed to send about 11 vacuum lines, transducer, special bracket for the intake manifold, and both speedo cables.Early cars had a transducer (I think that is the right term) that the speedometer cable ran to from the transmission. It was mounted up on the driver's side inner fender. A shorter speedometer cable ran from it to the gauge. The transducer, the vacuum actuator and the switch on the column was all there was to it other than the brake light switch (unless if I'm missing something).
later years I don't know.
Some Vac lines were on the brake pedal switch if I remember right.You lost me at 11 vacuum lines. I'm now curious about the signal the speedo put out on later cars.
All set ups from '78-'88 used a vac switch with the brake pedal to disengage the system when braking.Some Vac lines were on the brake pedal switch if I remember right.
I am smelling what you are stepping in.We-ell, since the shot you posted is taken from the passenger side perspective, more or less, additional shotf from the front and the driver's side, shot at about the same distance or even slightly closer, would show the same amount of detail at the same degree of resolution. That possible???
