Fitech efi system
wind-water-fire-earth
23
23
Canada, alberta
I am using it with a gn tank, sender and aeromotive fuel pump on my malibu. I would suggest to drive it a couple of hundred miles before tuning. I started making adjustments right away and it ran crappy.
I reset back to default with my initial settings and it's been running great! I am using it on a sbc.
Fitech now has a system that replaces the ls intake and all. pricey but no hassles for harnesses and stuff.
http://fitechefi.com/products/ultimate-ls/
Been a while since I've been on here , just been wrenching hard !!
23
23
Canada, alberta
Not to nitpick but, I see guys taking factory EFI engines and running aftertmarket systems. What is the advantage to this?
Not being a smartass, honestly curious.
No worries I feel you. I didn't wanna use stock intake or wiring ecm cause then I still have to pay someone to tune raither do it myself. The stock intakes flow great hard to find something better, I just really like the look too
23
23
Canada, alberta
Hell yeah, looking good!!! Keep us posted how the fitech LS setup works. I've been contemplating going with a self learning setup versus factory harness, ecu and tuning software.
My brother has the eldebrock self learning system on his 383 stoker in a 87 olds and he loves it no problems at all, that's what made me lean towards the system ! Finishing up the wiring and odds and ends should be running this week !!
23
23
Canada, alberta
Boys this car is nuts , so hard to keep my foot out of the gas. Never had so much fun, fitech system was a little pain in my *ss but so worth it in the end.
mclellan83
4,265
9,471
Pgh, PA
Was also kicking this idea around since my carb could probably use rebuilding and the LSA that I want to go with is so much money
23
23
Canada, alberta
having problems with my shifting, i dont know if its tune or the transmission its self. might just be 4l60e taking to much of a beating. hoping i can find someone using the ulimate lsx efi fitech. would appreciate it guys
