1973 Chevy Parts Hauler
Got out before it got hotter than the surface of the sun here in Texas and truck was still in the shade. Installed the headers(dropped right in as they should!) after cutting off a little bit of the down pipes for the stock manifolds, installed power steering pump/brackets after making a spacer to go with the headers, new soft fuel lines to the pump, installed thermostat/gasket/housing, and dropped in the distributor. I'm either lucky, good, or crafty as the balancer was at 8* BTDC and the distributor dropped in straight away. I'm buying lottery tickets later today.....
Texas has been so hot but this morning was just a little cooler. Got out and cleaned up the plug wires with Goop hand cleaner, swapped out the blue wire holders for a set of black one I think I bought in 90', detailed the distributor cap, cleaned up the permanent cork gaskets off the valve covers, new filter/vac caps on carb, and installed it all on the engine.
Also installed a new beer opener
lookin pretty good!
images
Ordered a new passenger inner fender as the original was rusted in a horrible place to fix. So one brand new inner and one old, crusty, rusty, undercoated inner and a plan to paint both with new paint. A quick clean up and paint would work........
Nope. Heat gun and scrapers.
Well, let's get out the sander
And while I'm at it the sandblaster
Now I can shoot some primer and paint both.
