Also, best luck on the seal. When you say it presses in easy, do you mean into the seal carrier or over the crank flange?
The old one is a Competition clutch I bought used with low miles on it. I think it is a 'Stage 2' clutch with '65-70% torque increase' over stock.
The new one is a Cyber which is sold through a local guy (he owns Fabbot, the company that makes the colorado AR5 swap parts to LS), it's made by the same company that makes many aftermarket clutches from what I understand and he just plans to buy enough to sell with his kits that he gets his own paint job on it. I know the seller and it was available quick. 814ftbs rating or something so more than what I need. Looking around it's the same as a Monster stage 3 which is a 550-700hp rated clutch. I am at the low end of that so it's a good fit for me.
I can say I paid just shy of half of what Monster gets for it minus the flywheel since I can't use the normal short crank LS flywheel with my setup.
We manufacture FBODY high performance street clutches. Get a single disc w/ standard weight flywheel from Monster Clutch Co. Order today!
monsterclutches.com
The OD of the seal pressed very easily into the ID of the aluminum rear cover. I could push the seal in with 2 fingers, no hammer required. I had to hammer the old seal out but the new one fell into place.
I went to my buddy (who I got the clutch from) and he had a few extra LS covers laying around. I traded him one that had a seal in that fit good. I think my rear cover ID was just too large on the tolerance for these new style seals. The 07ish Gen 4 cover he had that I measured was 0.002" smaller on the seal bore in the cover than my 00 Gen 3 cover.
I also looked at the National branded seal from the other parts store (Rockauto claimed it was the same as the old OEM seal) and it was not, it's the same as the Felpro. I have determined there are only 2 seals available. One is the F A G brand one and the other is the Felpro one. They are the same general style however.
What is the minimum allowable thickness on the flywheel? If it's cut too far, then you're going to smoke that new clutch in a hurry. If you know this already, then ignore my question. Only advising of this from experience.
Your clutch had the bejesus slipped out of it to make it look like that. Do you know the culprit?
Not sure on the min thickness. McLoed doesn't have it published anywhere? He only took off 0.017" so I am not worried. There is 0.050" of wear allowed on the new clutch before it's into the rivets so my gut check says it's less than the wear range of the clutch so I am OK.
I don't know the exact culprit but I have some guesses.
#1 the clutch was used (slightly) before I got it, I have put ~15k miles on it and probably 50+ passes over 3500 rpm clutch dumps at the track. Partially it's just wore out.
#2 the 2 step was set to 4000 rpm last weekend. It's usually at 3500. The timing is also is at 16 degrees instead of 12 degrees at 4000 RPM. The car is making more power down low that it probably ever has before. The track was OK and it hooked up good every pass. Didn't spin a single time.
#3 the clutch was slipping after I let off the pedal and the RPM rose, then sagged as it coupled up top in 1st gear. I said 'eh it's fine' when i glanced at the logs but I think that is a nogo. I thought 2000 RPM of slip across the clutch is OK for maybe 2 seconds but I think it is putting too much heat into it. I sketched on the snap below to show. The dotted line is the RPM curve the engine should make as it speeds up but the red line is what it does. It climbs up to 5500 RPM right after I let the clutch out, kinda hovers there like a the stall on a converter while the RPM picks up and then finally couples and drags the engine RPM down. This same thing happened 2 months ago when I raced and broke my clutch pedal push rod but it reved up a few hundred RPM higher and the rev limiter was 6000 instead of 6400 like it is now. There is too much going on for me to really notice the couple extra RPM for 1 second to notice when I am actually in the car.
#4 the clutch is probably just too small for the power I am making at the weight and a decent suspension that hooks.
I did get the trans install done tonight. Going to break the clutch in tomorrow.
