Seems we are both shitposting in our own threads today to keep them from being time locked.
Senor Rich got around to putting a ford TVS2300 with one of the demuse engineering adapter plates on an LS. Basically the demuse manifold is the same setup I have but I use the Maggie upper and lower tub halves with a maggie cooler and an adapter plate to put the GT500 bolt pattern onto the maggie upper plate, where the demuse kit just uses the maggie lower tub and a billet upper and non maggie water cooler.
I also run a separate 8 rib belt drive off the balancer vs. sharing the 6 rib off the water pump PS and Alt.
He mentions quite a bit about how you should get the cheap M122 & TVS 2300 blowers NOW before the price goes up. I hate to break it to him but the prices went up 5 years ago and honestly are at the point where the swap is cost-prohibitive.
I bought my 1500 mile M122 in 2015 for $200
Ebay takeoff 5.4 M122 are $800-$1500 these days
And Ebay takeoff TVS2300 5.8 13/14 blowers are $2000+ because they are bolt on upgrades for early 5.4 cars and they only made them for 2 years and few people upgrade them anyways because they are so good. I have seen 1 TVS2300 for $1200 I should have bought but it's still a big chunk of $$$ for power I have a hard time using.
He used a bolt on Roush/ford performance TVS2300 for a 5.0 (probably because it got sponsored, delivered at low cost, whatever, but that's probably still a $4k part even without the kit as a service part, and nobody in their right mind is parting out a roush kit or upgrading it.
But, it does make power. He got 650 with 15psi on a high comp L33 5.3 with E85 with tiny throttle body. I run the lq4 6.0 at low comp with 11.5psi and a smaller blower pulley & a 92mm throttle. My M122 is MUCH less of a blower than a TVS2300 despite the bolt pattern and overall size being really close.
But what I see again is that I gotta spin the thing past 6250! I have been shifting at 6250 and my drop RPM was like 3750-4000ish. If I can shift at 6750 my bottom end shift RPM should be at 4500-4750ish which is like an 80hp increase. Comparing apples to oranges a little here but with the table top power curve up top it's more evidence I gotta stop being a wimp! Haha!
It's just TOTALLY NOT WORTH spending $1000-$4000 on a blower plus the probably $2000+ on the demuse kit plus $500 on the maggie lower manifold.
Just put a turbo on the damn thing or spend $8k on a new maggie kit if you want a blower!
The TB isn’t the issue - boost will overcome it. Make an adapter to run a stock TPI TB or a 90mm chyna LS TB. You have a machine that makes what you desire.Oh, plus, unless you have a CNC and can make a nice GM round to oval blower adapter like I did,
Run a ton of adapter plates with an OEM type throttle body and cut a hole in your hood with ugly adapter plates
Or run an aftermarket computer that can control a Ford DBW setup (that is different than a GM setup) and buy a GT500 or late DBW V10 throttle body which is overprice because it's also an upgrade for 4.6 cars
You are stuck with a $635 DBC throttle.
Yowch.
China bad.The TB isn’t the issue - boost will overcome it. Make an adapter to run a stock TPI TB or a 90mm chyna LS TB. You have a machine that makes what you desire.
