I didn't paint the back side of any of my interior panels. Now I really feel like a worm.
You are fine as long as you avoid using white zip ties on black wire loom. 😉
Looks great! If you do anything to those rockets, I'd match the steery wheel with just a subtle outline of the raised edges. Charcoal gray or something a bit lighter but not to bright. Make a subtle statement that's easier to spot when someone is checking out your car.
Alright, I know I said I was gonna finish the wheelwells first, but the humidity dropped making it ideal paint weather. So I attempted to highlight the rocket emblems and it failed, so back to black they went.
My new front belts came in today and look awesome! Thennnnnm my wife called and her car died and she was stuck. So went to rescue her, thought I had it fixed, 5 mins after we parted it died again. We switched cars, I had hers towed and still can't get any code other than an EVAP issue(09 Mariner with no has cap system grrrrrr).
Anyways, it got dark and I came back to the Cutlass. Got the belts fished through the sail panels, and got them installed. I think they look great, but damn I've got alot more panels than I thought to prep and paint. Pics just because....
Adjusted the base idle and a couple other things. Still need to figure out why the rpms start climbing after 20+ seconds of idle time. It acts like a vacuum leak, but it's def not that.
Here is another short video with the cam chopping better as the engine temp is closer to op temp. Oh, fixed the trans fluid leak but now there seems to be either a water or oil leak at rear of engine 🙁. I'll have to look into that further.
Until then.....
Until then.....
Your tuner sucks! 😉
Your tuner sucks! 😉
Highly unlikely bro! I enjoy the challenge of figuring this software out and how one cell can be askew and cause the whole shebang to act goofy. I'm wondering if it's an AC related issue and the ECM thinks it's there. I recall disabling the AC functions and saved it, but I'll check when I get home.
Better get some quilts or something to lay on those when you work under the hood! You have sooo much effort in them!
