Wow...who'd have thunk it? Guess those older Corvette parts would have done the job. Doesn't matter now. Those look good and better than cap screws.Ha, 3/8-24x1"
Yeah I've gotta check the clearances, especially the "stop" riveted to the lower arm.I had those with brake lines with my Blazer upgrade
Took them off, They do not lock into the caliper and will come loose.
Also turn your wheel lock to lock, you may want to change your brake line retainer on the chassis to the S10 version it might hit the wheels
Locking into the caliper means there are some calipers that have a cast "tang" as it were where the banjo fitting cannot move to loosen once it's torqued down. If there's any pull or push on the line as you steer, along with vibrations, may loosen the fitting because there's no fail safe physical block to keep it from moving.Yeah I've gotta check the clearances, especially the "stop" riveted to the lower arm.
How you mean "not lock into the caliper?" I torqued them down, just have to keep an eye.
Naw, couldn't justify the $300 for the drop spindles.Drop spindles?
I used the G hose- had to trim the rubber strain relief off of it.
Jared,I used the G-Body Russell hoses too. I torqed them to the Blazer spec, like 40 ft. lbs., if I remember right. I don't see them pulling loose but I'll watch them.
