I got a quick question....the harness all the way to the right of the last photo, what is it? Has a vacuum line, 4 or 5 prong connector and a lone ground wire. I assume cruise control but wanna make sure before I ditch it. Would I have any problems if I just removed it and used a rubber grommet style plug for the firewall? I really wanna get rid of all the sh*t I won't use to make the wiring simpler......any input is appreciated.
I am 90% sure that is for cruise. On the inside of the car, does the harness come through close to the fuse block area? That's where mine used to come through before I pulled all the cruise harness out. I think the vacuum line was for the little cruise vacuum ball too. To fill in that hole I used the rubber grommet that was already in there, cut a piece of fuel hose to fill it in more, and then sealed the hole grommet up with RTV. That way I can still remove it if need be.
