There is also a fusible link is there not? Seems to me mine was burnt. Check for voltage at the power lug. I added a 4 gauge cable directly from the battery to make sure sufficient power is at the alternator.
I had a similar issue with mine 1981 El Camino SS .It has power seats and was "shorting" out and draining the battery .So I set the seat where I wanted and pulled the plug.
This is correct. Two wires, same ring terminal at the starter, both with fusible links. One to the bulkhead connection, one to the alternator. You'll never see a fusible link inside a vehicle. It goes to the bulkhead thats attached to the fuse panel.
Marshmallows would be optional equipment...😊
I always kept a Halon fire extinguisher in the Porsche. The Halon leaked out over time. They ain't cheap to refill, but still better than having the car turn into a bonfire.
