Best thread in fan switch
8,826
7,779
Melville,Saskatchewan
Looking for one that turns on around 180 degrees, shut off any temp reasonable. Pretty sure I have tried the Summit and maybe Painless both failed. Willing to pay more for quality and will buy a spare. Plan on upgrading to a 4 pin 60 amp relay and buying a spare as well.
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
the Summit and..... Painless both failed.
I've only used the Painful one, and, yes, I had a failure. I don't see how it could only tripping a relay coil. It prompted me to install a manual override. Of course, that only works as long as the water pump pulley stays in one piece (it fragged the last time).
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
what thermostat are you using, if your using a 180 you can will be on all the time and why do you want the engine to run that cool?
8,826
7,779
Right now whatever is a factory thermostat on a 260, assume 195. I may have a 160 but thinking a 180 high flow in the Performer going on the 350. Staying warm enough is not an issue on my 88, too warm is more the problem. I plan on getting a new condensor and A/C compressor for next year. Along with a GN flap kit, hopefully I can keep it around 200 max. I have blown a least one 40 relay plus the 40 amp relay board in a Flexalite controller. These fans draw some amps on start up. I have gone through at least 3 thermal switches maybe more. I have the low fans on a 20 amp illuminated switch direct wired to the battery with a 30 amp inline fuse. Yeah, too many failures to not have a manual back up.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I have had problems with thermal switches but it turned out I had a bad ground on the engine...the Fast sysltem I have now had a thermal switch for the fan so I'll see how that does, I have a bypass switch for that fan plus and other bypass switch for the push fan which is activated by the sensor rood through the fins in the rad.
8,826
7,779
Last push in rad sensor was bad out of box. I also had other Derale controllers that the wiring fell out of. Also had a Derale adjustable controller that self adjusted usually to 250 degrees.
Bri guy
845
225
So this is what I get to look forward to when my fans arrive 😐
Oct 14, 2008
8,826
7,779
Which is why I suggested the 4 blade, non clutch fan, other than the blades falling off after a ton of miles, nothing can go wrong with them. I'm sure the $200+ PWM controllers are nice and last as they should.
Oct 14, 2008
8,826
7,779
They have more than the website shows
(773)599-3067 ask for Frank
That looks like a good kit for Briguy. My controller is Ok, just need two $15 for the pair 60 amp relays and two 180 to 190 on and 160 to 175 off thermostats. I want to spend as little as possible but willing to pay slightly more for the Thermostat's IF they will last.
