1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Fuel Tank replacement suggestions
Discussion in 'General Discussion' started by jimsmonte80, Jul 15, 2017.
  1. jimsmonte80
    jimsmonte80 Not-quite-so-new-guy
    Aug 22, 2011
    35
    2
    8
    I purchased a fuel tank for my 1980 Monte Carlo from Quanta back in 2010. I installed the tank just last year after the car turned into a major restoration. Since then, every time I fuel up at the gas station I get large amounts of fuel spraying back out of the fuel neck. The fuel pump nozzle will not shut off automatically. I have learned that there is a common problem with aftermarket fuel tanks and a bad filler neck design. I would like some advice on an aftermarket fuel tank with great reviews and no more spewing fuel during filling. I was leading towards a tank from Napa. Never had issues with products from Napa, but then again I never purchased a tank from Napa. Thanks in advance!
  2. ck80
    ck80 G-Body Guru
    Feb 18, 2014
    523
    212
    I'm not sure that I necessarily believe the "it's a bad design" blame game for all cases of splash back when fueling.
    My 77 c10 is on the original tank/neck/etc and it does it. Has more to do with changes in gas pumps and nozzles since things were new.
    Now, as far as best quality in tanks, I can't say for 1980, but in the mid 80s spectra premium was at least a, if not the, OE supplier for gm when the cars were built. And they still make many of their tanks in Canada, although some stuff is in China.
    That's what I use.
  3. jimsmonte80
    Aug 22, 2011
    35
    2
    8
    I am going on what I found. GM makes an aftermarket filler neck to solve fuel spray problems. I have had many Gbody cars and never had this issue. So at this point, replacement is probably my only fix. Just hoping to find someone here who had replaced their tank with no fuel spray problems. I will go with that supplier of fuel tanks.
  4. 406 Monte
    406 Monte Greasemonkey
    Jul 1, 2016
    243
    82
    Minnesota
    In my 79 monte that I bought last August does the same thing. The previous owner put a new tank in but not sure of brand. I try to put gas in as slow as I can and it still splashes out:mad:. I know I don't like it! The 79 I had in the late 90's definitely did not have this problem.
  5. jimsmonte80
    Aug 22, 2011
    35
    2
    8
    I am pretty convinced about the design of the filler neck. I am ready to throw down $200 for a new tank without these issues. With the money I am losing in spilled gas, I would be ahead in a few months. I have a 383 stroker pumping out 462 HP with a fresh paint job and spilling gas everywhere is totally unexceptable! I am sure someone somewhere has bought a replacement tank that works better then OEM.
    • Agree Agree x 1
  6. 455'ed80Regal
    455'ed80Regal Master Mechanic
    Silver
    Nov 3, 2010
    360
    34
    Lincoln, MO
    The filler neck was a bad design on the replacement tanks. The ones that do fill right are few and far between. Stock filler necks are the way to go if you can find someone to swap it from your old tank to the new one.
    My stock tank fills great. When I get to the point of replacing it with the replacement GN tank, it will will be ordered without a filler neck and I will swap mine over to it. Problem solved.
    • Like Like x 1
  7. fleming442
    fleming442 Royal Smart Person
    Dec 26, 2013
    2,089
    833
    Huh, I thought I was the only one with this problem. I attributed it to listening to some dumbass bystander while I was installing my new Spectra. I have to fill it super slow to keep the pump from kicking off. The Spectra in my 67 Olds doesn't have the same issue.....
    • Funny Funny x 1
  8. jimsmonte80
    Aug 22, 2011
    35
    2
    8
    It seems like a difficult task to swap out the filler neck from the tank. Seems like a solid unit. The one peice design gives the filler neck support. Not sure how you could separate the two.
  9. jimsmonte80
    Aug 22, 2011
    35
    2
    8
    A spectra tank doesn't have this issue?
  10. pontiacgp
    pontiacgp Canadian Prime Minister
    Mar 31, 2006
    21,546
    2,858
    Kitchener, Ontario
    When you do get your new tank clean it and cover it with a good material to stop it from rusting. My spectra tank started leaking at the seam in the 3rd summer
Loading...
Similar Threads - Fuel Tank replacement Forum Date
Anybody need a free fuel tank????? General Discussion Aug 25, 2017
Fuel tank for 81 malibu General Discussion Sep 19, 2016
Fuel Tank Regrets!!! General Discussion Aug 19, 2016
EFI factory fuel tank General Discussion Feb 28, 2016
Return line to fuel tank General Discussion Jan 26, 2015
Share This Page
