Seems to work sweet by hand. No binding and not too much play. I like this way netter than that bolt/nut that was on it....Think it will be sweet after I get that bracket from summit. Did I surprise you with the end result of the tire valve? Surprised myself even.....Defensively original!!!! Looks good!!!!
How does it function?????
Actually it's tight. No slack at all. May not even need that bracket from summit now......Have you had someone sit in the car and press the pedal all the way down to the floor with you under the hood?
When the press the pedal down see if you can still move the throttle clockwise
I would love too......but its around 35 degrees...and raining. Plus I went to start it up and seen gas squirting out of the fuel filter 😂🤣..its a glass one..so tomorrow I will throw the metal one on. And see what happens..Well what are you waiting for then?!?!?!?!
Go light up the tires and see
