Now... not so Quick speedo cable question
Discussion in 'General Discussion' started by STLRegal, Mar 19, 2017.
  1. STLRegal
    STLRegal G-Body Guru
    Jun 22, 2007
    640
    74
    St.Louis
    i need to replace my speedometer cable that broke during my swap. What kind do I need? The speedometer is the horizontal type. Transmission was a th200, now it's a th350.
  2. Longroof79
    Longroof79 Geezer
    Oct 14, 2008
    8,882
    2,060
    Gainesville, Fl
    Does the car have cruise control? If so, there should be two separate cables...one coming from the speedo to the transducer, and the other coming from the transducer to the transmission. It doesn't matter if it's a 200 metric or TH350.
  3. Texas82GP
    Texas82GP Comic Book Super Hero
    Silver
    Apr 3, 2015
    4,221
    3,243
    Spring, Texas
    Jack, only the early cars (pre 1984?) used the transducer.
  4. Longroof79
    Longroof79 Geezer
    Oct 14, 2008
    8,882
    2,060
    Gainesville, Fl
    Jared,
    you're absolutely right, my friend. My bad...:doh: He did not mention what year and type car he has.
    The next thing I would suggest is go to the Rock Auto site and see what's listed for your car.
  5. STLRegal
    Jun 22, 2007
    640
    74
    St.Louis
    No cruise control. Thanks for the info.
  6. Texas82GP
    Silver
    Apr 3, 2015
    4,221
    3,243
    Spring, Texas
    The length is the key. Measure the length of your original cable and then buy a new cable for your application. The length is the primary difference. Does your car have the cruise transducer mounted on the inner fender?
    • Agree Agree x 1
  7. STLRegal
    Jun 22, 2007
    640
    74
    St.Louis
    87 Buick Regal.
  8. Texas82GP
    Silver
    Apr 3, 2015
    4,221
    3,243
    Spring, Texas
    I think I purchased a 100" cable for my car but haven't installed it yet. It was an educated guess on the length since my car had the fender mounted cruise transducer with two part cable setup but I'm changing to a one piece cable.
  9. mobileaudio25
    mobileaudio25 G-Body Guru
    Jan 12, 2012
    514
    136
    columbus, ohio
    I purchased the 100in length cable for my speedo and it was too long. I had to loop it under the drivers floor board and it gave me a bouncy speedo. I swapped it out for the 80 inch speedo and it was a much better fit. $14 from Autozone and I lubed it with white lithium grease liquid wrench in a spray can. No cruise control here either. Th350 . I have the sweep style gauge.
    • Like Like x 1
  10. STLRegal
    Jun 22, 2007
    640
    74
    St.Louis
    Went to the parts store and picked up an 80in. The original is a 2 peice but this one seems to only be a 1 peice. I was thinking 100 would be too long.
    • Agree Agree x 1
Loading...
Similar Threads - Quick speedo cable Forum Date
Nee a quick pic!!!!!!! General Discussion Monday at 3:04 PM
34th annual Arizona Nationals, Quick wagon General Discussion Mar 4, 2018
HELP QUICK PLZ Blazer Brake Upgrade Question General Discussion May 11, 2017
quick fuel gauge question General Discussion Apr 22, 2017
Quick question General Discussion Sep 7, 2016
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
