Sean's 78 Camaro Z28
Should we leave the wheels grey or paint them body color?
  • Leave grey
  • Paint blue to match the body car, the way the car was when new
Results are only viewable after voting.
Sean and I worked on the car today. The material on the Driver's side door panel had come loose along the bottom.......
So we pulled it, cleaned it up and glued it back with contact cement....
The repair turned out well. You can see this panel has been on and off a few times and has suffered some for it. My sister-in-law and I bought Sean these door panels. We paid a pretty penny. The quality isn't really commensurate with the price but they are still way better than what the car had when my brother bought it back in 2006. I didn't get a pic of the panel back on but there are pics like that in this thread.
While we had the car over on the main side of the garage, I went ahead and checked all the fluids and looked around under the hood. It's dusty under there but still looks nice...
I think later this year we'll likely change some fluids. It's already been three years since thrash week when we replaced the radiator, flushed the brakes, etc. That's hard to believe.
The car has a bit over 7400 miles on it.....
While we were at it, I got under the dash (very foolish of me) and adjusted the clutch pedal up. We used a Tick Performance (Tilton) clutch master cylinder for a 4th gen F-Body and the pedal height and stroke are adjustable.
A few years ago, the rod for the cluch master cylinder came loose from the pedal. We put it back together but somehow in the process the jam nuts on the adjuster backed off and over time, with use, the pedal got lower and lower until the car didn't have any clutch.
As this was happening, the cruise control stopped working. This makes sense, because we have a safety switch from a 4th Gen F-Body on the pedal that cuts off the cruise if the pedal is pressed.
When I adjusted the pedal up the last time, to restore clutch function, I was too conservative and the cruise still wouldn't work. This was just one of those things we never got back to so it was nice to address it today. The cruise should work now. It's raining here today so we didn't take it out and test it.
I guess that's it for now friends.
Nice. Looks like an assembly-line install (IMO, that's a good thing)
Thanks Brian. That's really the direction we were aiming for. Not super slick, hiding the wires (nothing wrong with that). Rather, just a clean install to hopefully look like that's how GM would have done it.
Sean and I spent Saturday doing maintenance on the car. We:
  • Changed the engine oil
  • Changed the fluid in the T56 Magnum (Dex III)
  • Greased the front end
  • Drained and refilled the cooling system
  • Flushed the brake hydraulic system
  • Flushed the clutch hydraulics
  • Adjusted the pressure in the tires
  • Cleaned the K&N air filter
The car now has 7455 miles on it. The transmission had never had a fluid change. I think it can now go at least 20k miles but we'll likely change it on time.
We're using the Mobil 1 Extended Performance oil and Mobil 1 filter. It had been about 18 months since the last oil change. The oil still looked fine though.
We last changed the coolant, flushed the brakes and clutch in April of 18 (the thrash week).
We didn't service the rear end as it has been done once since we got the car going.
Not exciting but it feels good that the car needs nothing for the next year. A few pics.....
I have a huge affinity for 2nd Gens.
I usually prefer the Trans Am of this gen but this thing is really bad *ss
Thanks. I still have trouble believing it's the same car we started with. All that time spent with my brother and seeing him enjoy the car he always wanted is the best part for me.
What accessory drive brackets did he/you use? They actually don't look out of place for the disco era f-body.
Reactions: Texas82GP
It's the Corvette FEAD which we bought from GM (water pump, power steering pump, alternator, tensioner). Then we went with the Holley A/C bracket for the R4. I agree, it fits like it belongs in there.
