Time for another installment. When we left off it we were moving into September of 2013. It had been seven years since Sean bought the car back from our Uncle. The body and chassis were restored. The glass was back in the car. the engine and transmission were in. It was still largely an empty shell though. The next piece of the puzzle was the driveshaft. We had Denny's Driveshafts build us a new shaft. It was a really good experience. We measured according to their printable form and then my brother called in and placed the order. The service and guidance/advice was great. Here is the new driveshaft. It was well packed and the quality is outstanding. There's just nothing like nice new made in the USA stuff....
And here it is in the car. This also gives you a good look at the Competition Engineering subframe connectors which I've hardly mentioned...
Here's a look at the rear disc brakes, traction bar, sway bar, etc. It's amazing how dirty this stuff gets just sitting around. A lot or most of the dirt is from all of the body work.....
Moving into October, we started connecting the fuel lines to the engine. We used the factory configuration fuel supply/return/vent lines. When we installed all new stock style stainless lines we were still planning to go back with a Gen I small block. If we had planned an LS swap all along, we might have plumbed it differently. Since the LS3 fuel rail doesn't include a pressure regulator or a provision for a return line, we decided to use the C6 Corvette filter/regulator. we found a place to mount it on the lower front passenger side corner of the engine block, near where the factory fuel and return lines terminate, near where the stock mechanical fuel pump would be. We used fuel injection grade hose and clamps to connect the filter/regulator to the hard frame lines...
The next issue was that the LS3 fuel rail has it's inlet on the driver's side and our fuel lines were on the passenger side. What to do? It turns out it was as easy as pulling the fuel rail and swapping it around. It fit perfectly. Now all we needed to do was get from the outlet of the filter/regulator to the fuel rail. The stock fittings are GM push lock. On the inlet side of the filter regulator we used aftermarket adapter fittings to adapt the push lock barbs to the hose clamp barbs. We didn't want to use rubber hose from the outlet of the filter/regulator to the inlet on the fuel rail due to the proximity to the header on the passenger side. After doing some looking, we sourced a stock braided stainless fuel hose from I believe, a fourth gen LS1 F body. That left us a pretty long gap. I ended up fabbing up a hard line out of stainless to bridge the gap. I bought a really nice hydraulic flaring tool that had the dies to make these push lock flares. I wish I had a picture of the completed line off of the car but here it is installed. You can barely see where it turns to the front and stabs into the filter regulator deep down in the picture. You can also see the little bracket we fabbed up to tie the hard line to the passenger valve cover....
Next we installed a new coolant bottle....
Next we worked on hooking up the power steering hoses. This was a little bit of a challenge on the pressure hose since the C6 power steering pump used a metric bubble flare fitting with o-ring and the gearbox took a good old SAE inverted flare fitting. The solution was to take a new pressure hose that was stock to the car and cut the pump end off of it. Then I used a repair fitting from Edelman that included the metric bubble flare fitting and a straight section of metal pipe. We initially installed it on the car with just a hose clamp holding the two pieces together but later took it off as an assembly and had a local shop crimp it together professionally.....
Next the new windshield washer bottle went in...
Around this time we procured and installed the throttle body. We went with an Edelbrock 90mm throttle body that had the late style four bolt pattern to fit the LS3 intake but was cable driven...
As you can see in the picture above, we also started wiring the car around this time. Ugh. The wiring. It was a really big job on this car. I learned to hate wiring. I'm ok at it. It is just tedious and time consuming to do a decent job. We started out with a Painless replacement harness kit specifically made for the 78-81 Camaro. The quality was outstanding as were the instructions. They did a great job building in flexibility into their harness. If I have any criticism, it's that they are a little stingy with supplies for what they charge. It starts out by mounting the fuse box to the firewall inside the car and then connecting the bulkhead connector to it under the hood. Then you start routing the harness to the lights and working on connections under the hood. This was a relatively easy part of the wiring. Here's a pic of the beginning....
This gets us to the beginning of December of 2013. More wiring and more progress under the hood to come...
