Gasket glue...The seal that goes against that lip on the cover & butts up to the oil pan rail needs to be fixed in place so it doesn't shift around during the install. RTV/sealant/silicone sometimes doesn't do a great job holding it in place.
It was recommended to me when doing the task the way you're doing it to use gasket glue to keep it where it needs to be.
Or how about this E6000 industrial strength liquid adhesive ?Gasket glue...
I tried using Gorilla Glue adhesive spray to stick the gasket to the timing cover, let it dry overnight, but didnt stick when I test installed the cover... Obviously didnt work...
Researching "gasket glue" I come across these... Which one am I looking for...?View attachment 192324View attachment 192325
Which one specifically do/would you use ?Stick with automotive adhesives. See a lot of stuff posted I wouldn't suggest.
Tin snips and RTV...You don't need to **** with the oil pan. Tin snips and RTV.
I bought JB WELD SuperWeld Extreme Gel Super GlueThat Permatex 80062 would be good stuff for a job like this. It will work for helping seal off that seam as well.
