Thats how my buddy did the sbc in my old Malibu..... With some extra sealant for the corner joints.I have never pulled a pan to do timing chain on a sbc, and in the late 80"s with plastic timing gears we did a ton of them, unless someone had installed a one piece oil pan gasket, I was taught by a chevy dealership tech on how to do it back when I was 16, I am 51 now, we always trimmed the corners off the back side of the rubber gasket support, used 2 small phillips screw drivers to "pry" down on cover untill it slipped into place, ya it takes a little work but thats how we always did it, it does take a skill set to do. Just my 2 cents.
Yea that's understandable, you can't always hear what they're saying by reading what they write.Gotcha. Interpreting the posted statements is hard sometimes. This is why as much info as can be input is beneficial when seeking help. The downside is trying to determine exactly what your situational abilities are.
If you haven't done this sort of thing & timing is important (gotta' have it running in x-amount of hours/days), I'd seek assistance from one of those family members if they're knowledgeable on the task. It helps to have someone that's been-there done-that for tips & tricks so you're hopefully successful on the 1st try.
Gotcha, I will most definitely try this route. Thank you !I have never pulled a pan to do timing chain on a sbc, and in the late 80"s with plastic timing gears we did a ton of them, unless someone had installed a one piece oil pan gasket, I was taught by a chevy dealership tech on how to do it back when I was 16, I am 51 now, we always trimmed the corners off the back side of the rubber gasket support, used 2 small phillips screw drivers to "pry" down on cover untill it slipped into place, ya it takes a little work but thats how we always did it, it does take a skill set to do. Just my 2 cents.
I would seriously encourage you to get a used original one cause those universals really do need extra work & parts to fit. Like I said before someone here should be able to hook you up with a good one to match the old one.A new aftermarket keyed steering column
Yea, I see I'll need a rag joint on the steering box and a Borgeson coupler on the column shaft... Maybe a new steering shaft...don't know until I look under the hood this evening...I would seriously encourage you to get a used original one cause those universals really do need extra work & parts to fit. Like I said before someone here should be able to hook you up with a good one to match the old one.
