It should be the bottom one on sender but hopefully someone else will verify. White thing has to be a vent maybe with built-in rollover valve???
Tape areas to be cut to stop fraying. Use a hacksaw, cut off wheel, or large wire/cable cutter.Fuel system day!
Was hoping to get farther today, but I apparently needed to learn how to do AN fittings. Started with not having anything that would cut through the stainless braid. Then figuring out how to spread the braid right so the furrel would seat right. I think I figured it out.
Tomorrow is another day. I'll finish the lines tomorrow and hopefully pressure test them to find out if I need to re-do any fittings.
After that then it's back to wiring. In cab wiring and finishing the engine wiring.
The best way is to duplicate the basic layout of the factory set-up.Right up against the intake using couplers, then run the rest out to the filter?
Thanks, my brain would not think of that.
