Trans go shift kit tv boost valve stuck
442_87
Jul 19, 2014
70
Make sure the governor is all together, it will not shift past first otherwise. Did you check line pressure?
Thanks for the help again olds 307 & 403
I didn’t remove the governor, as the kit didn’t have a gasket so I left it as is .
I haven’t checked the latest be pressure need a 1/8” to 1/4 elbow
Any thing else I should check ?
Intermediate servo?
8,825
7,775
Yes, check the servo. I installed it too tight the first time, shifted great, chirped second, till I lost OD and reverse. I installed it with none of the washers provided last time, gave the right clearance that way on my 2004R. I would double check the governor is all together, a check ball or spring in the pan is a dead giveaway. Get the adapter and the gauge on before anymore tests.
442_87
Jul 19, 2014
70
Thanks Again
I had dropped the pan last night, and didn’t see anything In the pan .
I did use on one shim on the servo worked fine when I checked perhaps I’ll remove that shim.
Need to get new transmission fluid and the adapter
Thanks again
5,709
12,216
If the fluid is burnt on the 1st drive, then I'd fear the clutches are burnt as well. I agree 100% with a line pressure check, changing the fluid and filter is not going to resolve a thing IMHO.
Did it work correctly prior to the shift kit install?
442_87
Jul 19, 2014
70
So basically the transmission is cooked?
It worked ok prior to the shift kit , it’s original transmission for the car and I’m not sure how many original km are on it.
Checked Home Depot , didn’t have rhe correct elbow .
So will check another store
5,709
12,216
Treat it right, IMO, to a proper rebuild. Depending on the location, $800-1800. Learn how to set the fresh trans up correctly and be done with it for another 100K miles.
When looking for the fitting, find someone near you that sells and makes hydraulic hoses. Get the fitting in steel rather than brass. It will be cheaper and last a lifetime as well. Also can be used for most anything upto that pressure range.
That fluid tells the story as far as I'm concerned.
442_87
Jul 19, 2014
70
Yeah I think I’m gonna give a break today, going to call a few transmission shops in the morning
Yeah looks like it’s probably done.
Sigh didn’t need this lol
442_87
Jul 19, 2014
70
ok I managed to get a fitting here are my readings
Full TV @ 1000 rpm
Gear Psi
P. 225-230
N. 225-230
D4. 225-230
D3. 225-230
D2. 200
D1. 200
No TV @ 1000rpm
Gear. Psi
P. 60
N. 60
D4. 60
D3. 60
D2. 200
D1. 200
Will call transgo in the morning. What do you think of these numbers?
Thanks
8,825
7,775
