Had to grind on my tighrods to get my new wheels to fit.
That is pretty typical with GTA's. What brakes/spindles do you have in front? Are the Wheels GTA Rears or Fronts?
GTA fronts. 4 inch backspacing. Stock brakes with 2 inch drop spindles. Do not remember the brand.That is pretty typical with GTA's. What brakes/spindles do you have in front? Are the Wheels GTA Rears or Fronts?
I am not sure if they are fronts or rears. They all have 4 inch backspacing. Came off a t type. The other set I have are a little different. Center cap holes are smaller, but rims are nicer.On my T-type, I run GTA Rears in front with stock spindles modded for 12" brakes (which space the wheels out 3/8" or so). With GTA Fronts in front with big brakes, you have to do fender lip surgery to get 245 and larger tires not to rub, so rears give a little more room.
I had to round the tie rod ends on mine to run the rears in front without a spacer - show below with my 12" B-Body brakes (I don't thing Rears in front possible without a spacer using the stock brakes because the wheel hits the spindle arm) View attachment 70986
I like the polished wheels better.Had to grind on my tighrods to get my new wheels to fit. Then I took it for a quick spin. Don't know if I like the look of that style of rim on my car. I think I like my polished wheels beter. What do you think. View attachment 70981
I am not sure if they are fronts or rears. They all have 4 inch backspacing. Came off a t type. The other set I have are a little different. Center cap holes are smaller, but rims are nicer. View attachment 70988
