Now after reading this in the other thread I need to ask if you are trying to get the lighting for when you turn on the parking/headlights? Or is this to power the back light when the head unit is on? If you need the back light on when the key is on then you'll need to either tap in the fuse box port at the RADIO fuse which is for circuit 141 (uses a brown/white wire when factory hard wired in), Feed, Ignition Switch, "Accessory & On" Controlled , or tap into the brown 12 gauge accessory power wire (circuit 4, Feed, Ignition Switch "Accessory & On" Controlled, Unfused) to run a new fused line to the head unit. This way, key at On or Accessory you'll have the back light. I can't figure out what green wire that you did tap into to power it.
wiring up gauges
Connect it to the fuse box somewhere that only has juice when the key is on. Use a test light. U can buy a fuse adapter that simply plugs into the fuse holder/hole where the fuse slides in and lets u use another wire off the fuse box. Can be bought at any parts store...do this for the volts...
Within this post it talked about using a dark green wire which turned out to be one of the rear brake lights I believe since that was the only dark green I saw. I am really just looking for the ilimunation wire that turns the screens dark and puts the side lights on when the headlights go on.
you like to kick a man while hes down ehHis problem is he skipped step one: quadrajet
