Hey, Clutch, welcome to my world. The Monte is back under it's cover for who knows how long while I deal with the S-10. For it's part the S-10 not only needs a complete front end brake job including the hard lines to the ABS block, it also has exhaust pipe issues and at least one box panel that is starting to display acne in the vicinity of an old repair, as well as needing all its seasonal maintenance as my daily driver. The van is on the road but its IAC software subroutine is driving me nuts because I can't get the idle at rest to drop low enough, fast enough, to let the engine shut down without trying to diesel. IAC value has to be consistently well below 9 across the temperature range and while I can get it to 5, it won't stabilize itself there; and gas for the van is 10.00/gallon up, and it has all the aerodynamics of a brick made from jello.
I have a complete wheel assembly waiting at the border for me for my vintage Harley but border crossing protocols still demand Covid Checks and both sides of the line have Federal Departments of Health that are so paranoid that the rules aren't likely to be amended until this current panic about variant BA-5? has passed; (Like it is going to be the last variant, y'know...)
I can' find the parts necessary to mount the two-up seat assembly for my other ride, a 47 Indian, and the stock seat bracket does not accept the larger seat pan; and is not easily or practically modifiable even if you can find one.
Apart from all this, I have a vegetable garden that is so overgrown with grass that all the rhubarb has gone to seed, the house trim needs to be repainted, and the A/C wall unit for the day room needs to be removed so that the window can be rebuilt.
Finally, if I am lucky, I can get about 4 hours of work time from my body before most of the muscles start to go on strike for better working conditions. As for your 100 degrees in the shop, I do agree that is pushing the heat limits, particularly if it isn't air conditioned. The sun does not hit my main door until after 4 so incoming heat is not so much of an issue. That A/C unit from the house was supposed to be moved into the garage 7! years ago which sort of explains how backed up I am, LOL.
Summarily, you can never have too many projects, the problem is too little time and too many diversions. As frustrated and p*ssed as you may feel, you WILL get them all done, just be aware that you are, as are we all, the ongoing target of Mr Murphy and his insidious plots to cause Sh*t to happen and at the worst possible time. DUCK and Cover, here he comes again!!
CopperNick sends
