In ground..ish? They are under the concrete front steps. They are hollow on the inside. So where the actual nest is under the stairs I don't know. It could be on the ground or even elevated really.In ground or paper nest?
Have to ask someone and see if they might know. That’s a difficult deal. 😓In ground..ish? They are under the concrete front steps. They are hollow on the inside. So where the actual nest is under the stairs I don't know. It could be on the ground or even elevated really.
What's that say on it, M20x1.5?I had to do it just to see if It would work. My Subaru Impreza WRX oil drain plug came yesterday and I had to see if it would work. I couldn't wait until after work.View attachment 204800
It fits perfect! Tonight that cab goes back on! And I'll go until I can't. So if you ever need to plug a 9th injector hole there you go Subaru drain plug.
Can get them at your local Orielly's, for a few different cars. I use them as T56 Skip Shift Delete Plugs after I machine the Flange off.Exactly
Supercharged111 this is one in my C5Z06 and the wires tucked, if your OCD is like mine.
I run it in the lathe and put a slight taper on it, once it digs into the case aluminum in that hole it self seals. You see in the pic how far in it goes and it stays there. Little RTV or loctite on the threads if you want the insurance but I've never had one come out.Once you whiz the flange off, what eventually stops the plug from turning in more?
Here it is in my FBody T56, same way in the Corvette T56 just a plug to plug the hole, doesn't interfere with the linkage.
