What Happens to Folks?
The previous rims I do not recall the offsets but they were 14x7s (I had to use one inch spacers up front) and 15x8s in the back is what the current owner used I just changed the mags last year. Right now I am currently using 15x7s up front and 15x8s in the back. If I remember rightly the front wheels I added a quarter inch wheel spacer and longer studs to give me some clearance and the back wheels I use the one inch spacer and took a little bit off the studs to make the rims fit because I couldn't get the offset I wanted. I'm not too sure about wheel spacers on the drive tires but I'm not cranking serious horsepower out of it so I'm not too worried the attached pics are the wheels I ordered from jigs I did swap out my center caps with the old mags.
I could see the 14's being an issue. Did you re-check w/the 15's & they required the .250" spacer?
I guess the SPC arms are usually intended for an app that would most likely have had larger diameter 'performance' wheels which likely would have cleared.
Reactions: 64nailhead
They required the .250 spacer
What's up w/the spacers between the BJ base & the bottom of the BJ end-plate? I'm guessing that's part of the issue.
I know my SPC arms didn't have any spacers.
I see we went from "what happens to folks" to "what happens with wheel spacers". whoa
That would be incorrect. It went from "what happens to folks" to a comment about the guy that swapped to a flex fan & another comment from a guy that used wheel spacers which were related to the topic of people popping in when needing info advice & not necessarily posting daily.
Reactions: 88AZSS
IT'S ALL ABOUT THE WHEEL SPACERS!!!!
Back onto topic - how many members would you recognize in public if you ran into one? Rarely do we get a picture of a member with their car, except the flux core splatter master with a helmut on?
Reactions: 350Regal
Don't knock fluxcore.
We are working on details for a West/Prairies meet up to address just this problem. I expect Rktpwrd to throw a flaming punch my way once he gets a clean shot.
street fighter art GIF by haydiroket (Mert Keskin)
Sorry about that...lol...
