I have a GN tank with a racetronix sender/ pump with a walbro 450. The gn tank is a spectra . This is in my 83 cutlass. Supercharged ls . Works great, but is a little slow to fill ,like it doesn’t have enough venting .
Hey, to the guys running the Aeromotive Gen II Stealth tank, I just mounted mine tonight and wtf? The sending unit is right smack where the tank mount brace is?!? You guys have this same issue? What were they thinking, they claim it’s a direct fit unit. I’ll have to cut away part of the brace to get this to work, although I’m reluctant as it may have some structural connections to the trunk? Really disappointed.
Tell that to all the Buick guys running factory tanks. The factory baffled tanks are still the best.The EFI factory baffling doesn't work very well. That's why I would recommend something more like a Hydramat.
Yeah, and I bet they're not sumped with external pumps either, right? I'm telling you from a ("spirited") daily driven experience. Go around a traffic circle or exit ramp with less than 3/8-1/2 tank, and the engine will shut off. I try to keep the tank above that.Tell that to all the Buick guys running factory tanks. The factory baffled tanks are still the best.
Correct, most guys will run a single 340 or larger pump in the stock GM baffled tank. Some of the higher powered guys will run dual 340's in the stock tank.Yeah, and I bet they're not sumped with external pumps either, right? I'm telling you from a ("spirited") daily driven experience. Go around a traffic circle or exit ramp with less than 3/8-1/2 tank, and the engine will shut off. I try to keep the tank above that.
