Olds Cutlass Supreme 1978 from Chile
7,989
18,697
Sorry. I've never heard of air shocks for the front. I've never heard of a gas charged shock being thought of as a hazardous product either.
6,832
6,741
Do you have any auto part stores in your area that sell new stuff? They only make air shocks for the back to raise the rear end for looks or for heavy hauling to level out the car for handling. Your 260 will never be fast, so just make it look nice and put dual exhaust on it that you can also use on any other oldsmobile engine you put in there later.
wnagel
133
26
Santiago Of Chile.
Is terrible, If I import a gas shocks , for example , usd100 the shipping price is USD400 plus 26% tax.....
wnagel
133
26
Santiago Of Chile.
Here in Chile , There are virtually no spare parts for olds, nothing, for chevy SBC has a lot......
7,989
18,697
The Chevrolet Monte Carlo takes the same shocks.
wnagel
133
26
Santiago Of Chile.
Yes, but in Chile is impòssible to find a correct shocks for this cars....:(
wnagel
133
26
Santiago Of Chile.
Well, the final desision, is :
Rocket 350 casting 3955582 , with comp cams rocket arm , 040 in main engine and 030 un crankshaft. with DUAL JET.
THM 375 transmission.
Someone use this transmission? (375), i would like to know the experience from other user...
I need to put a dual exhaust , but I can see how due the space that the car has...someone can help me with this?
here is the engine...
Thanks
Waldo.
8,826
7,779
Too bad it doesn't have the Quadrajet but it will still be an improvement. That is the good, solid main casting block. Does it have a stock camshaft or is it aftermarket? I cannot see the video. The 375 trans had an A and B model. One was a heavy duty TH350 and the other was a light duty TH400, either will be fine with a mild 350. The 400 version will require your drive shaft to be shortened. Your stock TH200(C) is just plain weak, good idea to dump it.
