I drove mine down to Del Taco for some grub. Loud-mouthed fat chick who took my order LOVED my car. Not sure how to feel about that.[/quote]
That is classic, we have all been in that spot before, kind of like when the drug dealers on the corner on my way to work whistle at my car and I think oh god light turn green now
I put a new sticker on the plate so I can drive it. Got pulled over on Saturday for the expired sticker and there is a benefit to old age, the officer must have believed me when I said I forgot it so he just said to have a nice day... 😀
well not "today", but -- installed a Rallye instrument cluster on my 1984 Cutlass - rellay happy to understand what's happening under the hood. Used LED's everywhere during the conversion :
More details in my build thread.
On my 79 Cutlass , replaced my water pump and the original timing chain and gears.. the cam sprocket was still the nylon one and was cracked all around.117,000 miles on the original chain and gears
this last friday, I'd finally procrastinated enough, and started the turn signal switch on my steering column change. I'd found this one in a 85-ish monte ss that had been hacked apart by more than 1 sawzall... oddly the floorshift-steering column was still in place, only without the turn or tilt stalks,wheel, or usuable lock cylinder. got the switch and lock changed over friday afternoon, and the dye done yesterday.
difference between duplicolor and sem:
Fabricated a new exhaust pipe (driver's side) from the exhaust manifold to the muffler using four 45 degree elbows, some straight pipe, one 90 degree elbow and a mig welder.
I also received in the mail from Amazon the following: i.) Standard PS-64 Oil Pressure Switch with Light with three ("3") contacts; and ii.) ACDelco PT139 Female 3-Way Wire Connector. I am going to install the PS-64 in place of my AC Delco D1811 so that I can use the extra contact for an idiot light as a ground for an idiot light. I am NOT getting rid of the gauges. I just want a light to come on if the oil pressure is low so that I will be reminded of this situation in two different ways.
Cleaned this puppie up, now it will sit until I figure out what engine and trans is going in
just put in a dual air intake from spectre, replace spark pugs, change oil, and put my cutty to the ground with 3" lowering springs
