Hope you didn't pay the guy. Another reason why I learned to do it myself, and hate people in general.Ok first tuning appointment and I got stood up. This is going to go well I'm sure
Injector timing and pulse width really, same as gas but all injector control.They're f00kers alright. Diesel tuning is foreign to me. I suppose I could at least crack one open and see.
After more research and brain racking I came to the conclusion that this truck has the Sonnax repair kit installed. As removed, it was set to function with the PWM as the general intended. Nothing was wallered out, so I feel that it shouldn't have had the TCC slippage, but again all I need to do is keep that inner purple valve pinned to the top. After fishing out the rest of it, I saw that I could flip the aft valve and have a nice stack.
Instead of the spring going inside that valve it can sit on top, has a centering tit on it.
That spring is pretty stiff too. It had an ample but realistic amount of preload when I put it back in. I really hope this is it, one and done. If not, it's gonna get spendier for him. I have to wait until tomorrow to get a decent gasket from a local trans shop before I put the pan back on and pick up a fan clutch, his is locked solid. Sounds like a d@mn airplane at 3000. Plus I think his cat is plugged. More to come.
What type of Lucas product did you put in the PS pump?So this whole thing ended up being a slam dunk. TCC slippage is gone, truck is more responsive and a jillion times quieter with the new fan clutch, and I squirted some Lucas into the PS pump and that shut it up and smoothed out its operation. I got $40 more than I asked for labor too, so he must be happy.
Considering a diesel fires off of pure compression, no.Yeah, then do you advance timing until you stop seeing gains, is knock a thing with a diesel? Probably akin to learning the same things on a new airframe I suppose.
