I picked up a few necessary items, nothing fancy. I did spring for a Pertronix cap/rotor kit, Delco plugs, and reusable Fel Pro valve cover gaskets though. IMG_20231120_174303265.jpg
Turns out I still need about another 12 feet of vacuum hose...
And more for Jr.'s Monte, the Super Brights LED's that mclellan83 suggested. Will be getting the front amber 11157's & back up 1156's but will be waiting on the back ordered tail light red 1157's. Then I hit the yard again on a quick trip for more wire sections for more harness repairs between both Monte's.
do you kids do the relay upgrade when you do this? it draws power straight from the batt vs the round about way via fuse box? it's worthy even w/running the o.e incandescent bulbs.
I've only seen the relay upgrade being for the headlights & mainly for the up graded/brighter headlights. Only thing I know needed with the other bulbs will be the need for a flasher designed to work with LEDS. There are those wire in resistors that is needed for each bulb used but those have to be careful on where they get mounted cause those generate a lot of heat. For no flash bulbs I've yet to see them draw enough power to need any relay help, just plug & play other than ensuring the polarity in matched positive to positive in the socket.
And more for Jr.'s Monte, the Super Brights LED's that mclellan83 suggested. Will be getting the front amber 11157's & back up 1156's but will be waiting on the back ordered tail light red 1157's. Then I hit the yard again on a quick trip for more wire sections for more harness repairs bewteen both Montes.
What year is the Monte?
