I removed the wiring for the inline pump and installed the harness for the in-tank. I had a pink copper wire for the fuel gauge installed since the aluminum wire was dead do I just had to pull that wire from the trunk area and slide ti through the dash to the passenger side so I could tap into the fuel pump harness which has the wire for the gauge. I put the new gas tank in, connected the AN fittings for the pump and return lines and positioned the vent line. Connected the electrical, checked the gas gauge to make sure it was working, it climbed up to E so that was a good sign, took a drive in the Jeep to get 5 gallons of gas for the GP. I put the gas in and checked the gauge. just a little more than 1/4 tank so that was correct, then I fired up the GP and fuel pressure was good so I shut it down and will check for leaks and to make sure the harness is tucked away......![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
