You do know these F150's are a gateway drug to chainsaws & lawn tractors.
^^^^^ he's right you know. I dragged this home today.
I fail to see the problem. In fact, I was zooming in to see if I could read the model number off the hood...
All I can say to that is I'm jealous, and, sorta need the same type of thing for now. I've decided tonight were going to be moving again as soon as I can pull it together, but, who knows how long that would take.It's a 2130. It was 20 minutes from my place. It was still with the original owner. I paid $100 for it. It has some issues but it runs and mows. I think it has a 38" inch deck, paint is nice, hour meter reads about 300 I think. I really haven't looked it over all that well but for $100 I'm not too worried about it. I've never had one of the AGS machines; all of the 2000 series I've played with were hydros. It's a weird system, gear driven but operates a bit like a hydro.
I bought it mostly because I wanted something with a bagger. Leaves are about to start falling and the bagger makes cleaning them up a lot easier.
View attachment 206736 View attachment 206733 View attachment 206735
I have an 08 Sierra with a 5.3 LMG (VIN 0). I deleted the DOD when it had 82,000 miles on the clock. I didn't do anything with that relief valve. It now has over 207,000 miles on it. Hot idle, it has about 28-30psi. Cruising down the highway, 40 psi. Cold start, maybe 50 psi. It has used some oil but when the gas price spiked, I went into miser mode and it isn't using. This is all just for y'all's information. At the time I swapped the cam and deleted the DOD, (2012), I hadn't read anything about removing that relief valve.Yea, if I had one I'd want to try what I'm thinking. That relief was in the oil pan above the oil filter.
Yup most don't know about it, and when you drop the pan replace the O-Ring on the pickup tube with a new red one, put it back together. Did that with my truck at the 180K mark because it needed a new pan gasket. Oil Pressure cold is 60+psi, hot is around 50psi idle, that's now at 198k miles.I have an 08 Sierra with a 5.3 LMG (VIN 0). I deleted the DOD when it had 82,000 miles on the clock. I didn't do anything with that relief valve. It now has over 207,000 miles on it. Hot idle, it has about 28-30psi. Cruising down the highway, 40 psi. Cold start, maybe 50 psi. It has used some oil but when the gas price spiked, I went into miser mode and it isn't using. This is all just for y'all's information. At the time I swapped the cam and deleted the DOD, (2012), I hadn't read anything about removing that relief valve.
I knew about the red o-ring but it's a good thing to mention for any who don't.Yup most don't know about it, and when you drop the pan replace the O-Ring on the pickup tube with a new red one, put it back together. Did that with my truck at the 180K mark because it needed a new pan gasket. Oil Pressure cold is 60+psi, hot is around 50psi idle, that's now at 198k miles.
I recently saw a YouTube where a DOD delete was done and he pulled the relief valve and put a plug in it. It was the first time I saw that. Ignorance is bliss, I guess?Yup most don't know about it, and when you drop the pan replace the O-Ring on the pickup tube with a new red one, put it back together. Did that with my truck at the 180K mark because it needed a new pan gasket. Oil Pressure cold is 60+psi, hot is around 50psi idle, that's now at 198k miles.
